If your system is clean and working, the stock two row works fine for most cars up to maybe 175 hp. The stock two row cooled my 250 for years.
The six cylinder block is long and the water path is pretty convoluted. It goes from the pump, thru the block, then up the back of the head, then to the front of the head. Some gets diverted for the heater, and some gets diverted as a bypass when the thermostat is completely closed just to keep the pressure down.
When the water gets to the back of the block and begins to turn up into the head, the flow slows down and a ton of crud accumulates there. The junk accumulates over the years until it becomes little rusty chunks that can break loose. This crud sometimes flakes off, goes thru the head, and ends up in the top tank of the radiator. It then either blocks the tubes or gets in the tubes to slow the flow.
Then, also as the radiator ages, the lead in the solder begins to corrode and oxidize and a thing called "lead bloom" begins to grow over the tubes. Looks like chalk. It eventually grows over the tubes and blocks them off.
All of these things begin to take a toll on the radiator's abililty to shed heat. Then the owners start chasing problems all over trying to solve overheating problems. It usually comes down to rusty crud in the cooling system.
A couple of suggestions. Generally, if the car overheats at idle, but is good at cruise, the fan is too small or airflow is blocked. Conversely, if the car overheats as speed but cools back down at idle, the water flow is too little (or blocked).
