I have pretty much tried everything that my knowlege will allow for...
I replaced the solenoid, the grounds (starter and battery), tried a direct lead (and jumped off the solenoid to send the maximum voltage to the starter),and check the starter to make sure the bendix drive drives out the gear all the way. I have also checked my flywheel - perfect, not bent, chipped, or broken teeth, but just in case, I also turned it several times. However, everytime I try, the starter engages, drives out the gear, but the gear just sits there and spins - the bendix gear is NOT making contact with the flywheel - the starter gear just sits there and spins (which is what led me to the flywheel question - is the bendix gear in the starter too small and can't reach the flywheel or reverse....). ?????????????????????????????
