I'm an advocate for any coherent modification but here's my $ .02 :
THREE important carbureted' 'blow-through' forced induction
considerations are :
1) the NA fuel supply to typical carb bowl is usually @ 5-7 psi (Weber a little lower) BUT with boost, fuel pressure needs to be raised equivalent to normal pressure PLUS boost. At 0psi boost (run and cruise), fuel supply is @ 7 lbs to carb from pump, at @ 7psi boost the fuel pressure needs to be @ 14 psi to keep it flowing
into not out of carb ...
2) Conventional Power Valve operation on carbs adds fuel with drop in intake vacuum under acceleration or WOT. Boost thru carb obviously needs OPPOSITE Power Valve operation - opening max with intake pressure not vacuum. Some way to operate carbs' PV with boost pressure is needed.
the universal Holley 4Bbl Carb
( '4150' ) has a lot of info available on Forced Induction mods ( googl e "hangar 18 mods') and readily available parts, jets and aftermarket unique operating Power Valve made for boost application.
The Holley
2300 2Bbl carbs are universal as well and are 1/2 a Holley 4Bbl so all the mods work on it as well.
1100 1Bbl can of course be modified but starting with a
350 CFM Holley #7448 (2300 series) 2Bbl is likely a shorter route.
3) Draw-Through Carburetors setups don't need carb fuel bowl pressure compensation
but where Blow-Thru boost makes carb CFM act LARGER than at NA, Draw Thru needs huge NA to boost CFM capability . Early BOP Draw-Thru setup used a unique
ThermoQuadrajet 4Bbl with EXTERNAL PV control from intake manifold pressure switch - vac/pressure xover and Draw-Thru necessity huge non-boost to boost CFM rating of 280 to 900 CFM !.
Nevermind turbo
INTERCOOLERS - BOP draw-thru on 250 Bernoulli Effect' from intake needed coolant circulation
HEATING to prevent plenum
icing ! ...
the Vortech supercharger on the current 250 uses modified Holley 7448 350CFM thru a simple 1 X 2 adapter .
Hav efun
