This was starting on the end of the Offy 3bbl post, so I figured I'd move it out for discussion as it's own topic. Better for searching and responses that way.
First...here is where we are. We got off of the Offy topic and on to the Aussie 250 2V that ws converted to 4V. Debate started about which way to better mount the 4V. One person has theirs mounted with the primaries perpendicular to the engine (primaries are on the front part of the intake) and another has the carb mounted perpendicular to the engine such that the primaries are parallel to the engine.
School of thought for the second set up is more even distribution of fuel for the fore and aft cylinders. I think the downside of this is possible problems with fuel flow through the venturis, especially under heave acceleration.
If you do the first set up, then the forward cylinders may have a minutely better fuel mix (or richer at least) while the primaries are in use.
Then the question came up of plenum height (adding a spacer). Plenum height will make a difference in power. It is two fold.
1) The fuel/air mix is allowed to cool slightly allowing more power. I think this is slight.
2) Gives a more ready reserve of fuel/air read to move to the next cylinder instead of waiting to be drawn through the carb. It also allows better mixing of the fuel and air.
So...any thoughts, comments, questions...let's start.
Slade
Slade
