1969Falcon
Hello all,
My first post after two years of lurking. Unfortunately, I come to the forum with a question about some car trouble.
Yesterday, I was driving my 69 Falcon with a stock 200 six and C4 transmission and it started bucking and stuttering. The problem got progressively worse, although I was able to limp home. I determined it is a fuel issue. All my ignition components are good and hooked up correctly, the battery is charging and holding the charge just fine.
Yesterday afternoon I replaced the fuel filter, and swapped a different fuel pump in. Didn't make a lick of difference. I tapped on the carburetor to see if the float was stuck, and nothin' doin--although it did seem to make a very shortlived difference. There isn't anything obstructing the fuel line to my knowledge.
I noticed the problem occurred when I would roll just onto the throttle, and subside a little as the revs went up. Starting it today, the engine hardly runs at all, even at idle.
FWIW, the engine has what I believe to be the original carburetor, though the engine itself was rebuilt a few thousand miles ago. Car was running fine until yesterday.
Any thoughts?
Here's some pictures for your troubles:
Any thoughts?
