I'm converting to an electric pump and need to find a blanking plate for the stock pump. there are plenty for 289's, but none for my 200. Are they the same??
Fuel pump cover should be the same as a 302. Ford pretty much only used two. The long Cleveland style and the other which works on just about everything else Ford made.
BTW if you check you might notice that those fuel pump block off plates also can double as EGR block off plates. But that is only for testing purpooses as it is illegal to disable your emmisions gear
