JoeCrozier
Beginner question for everyone:
I've posted elsewhere on here about how I'm rebuilding a 144. Well, I had dual action fuel pump (pictured):
And while disassembling it to clean it I found some crushed up springs and valves inside of it and figured it was time to rebuild it. Rebuild kits were more expensive than just buying replacements, so I bought this fuel pump off ebay:
Obviously slightly different (and single action, figure that's fine because i don't care about vacuum wipers), but seems like it should fit.
Well, the 'lever' doesn't seem to move as much as the old one (if that makes sense) and so even when I pretty firmly push it down, the fuel pump cant get close enough to the engine to bolt on (pictured, obviously there'll be a gasket eventually)
Can the lever travel be adjusted? Do I need a spacer or something? Am I doing something wrong? Did I buy a dud?
Any help would be appreciated
