I have a few problems and I'm wondering if they are fuel pump related.
1) Should my fuel pump hold fuel in the line from the fuel pump to the carb after that ca is turned off? When I pulled my fuel lines this morning to do some work, there was no fuel in the line from the pump to the carbs. That doesn't seem right to me. I'm thinking my new fuel pump may be leaking as well as my old one.
2) What PSI should my fuel system be running? I'm going to do a check this afternoon, I'm wondering if I'm getting enough fuel and maybe that is causing my lean condition.
3) Similar to #1, fuel my fuel pump be able to hold fuel from the tank to the fuel pump when the car is off?
Slade
Slade
