So I naively thought that I was just going to go in and replace my water pump. After having pulled the front grill, radiator, and fan I thought I was good to go. But then the lower bolt on the pump had to sheer. Luckily, it broke with about 1 1/2" sticking out of the block. So I went to work. Drained as much fluid as I could, jacked the front end up a touch to for the remaining coolant back, plugged the waterway with a rag, and proceeded to dump copious amounts of pentrating oil onto the bolt and let 'er sit for a day and a half. Gave her a twist or two (rocking back and forth with the vise-grips) and managed to sheer it off with about 3/8" poking out of the block. I've tried a hammer on bolt loosener and that failed. So now i'm pulling the balancer and timing cover so that I can get in there with the hot wrench. That guy is stuck in there good.
So here's where I ask for advise:
Since the timing cover will be off, I figure I'll go ahead and replace the timing chain and gears. I don't "plan" on doing a major overhaul on the block yet so should I sink the money into the double roller, or just go stock for now?
I had acquired some chrome (grade 5 steel) bolts to replace the bolts for the pump and thermostat housing. They're purty! Anyway, should I stick with the chrome or take 'em back and order the stainless bolt set?
Also figure I'll go ahead and replace the balancer since I've got it off. When I was looking at the gaskets I saw something called a "timing cover repair sleeve". I've never heard of using one. Is this necessary if I'm just planning on getting a new balancer?
Should I pull the oil pan or leave it in for this procedure? Looks like the timing cover gasket comes with some pan gasket to be trimmed into place.
Any other advice? I've got a sneaky suspicion that I'm going to just have to drill out that stupid bolt and chase the threads. Given the amount of liquid wrench I've already thrown on this thing, I don't think it's just going to magically break loose with a little heat.
