red_stang65
It all started with a major fuel leak around the carbureator. After rebuilding the carb and still seeing the same leaky mess all over the driveway, I replaced the fuel pump assuming the old one might have been allowing too much gas to flow through.
This seemed to work alright, though the car would still act squirrely after about 10 mins. and would idle rough. I then went back to the carb to make sure the choke wasn't sticking (it wasn't). However, I decided to take it off again and make sure all the parts were in it correctly. Come to find out I was missing one little ball in one of the holes. Also, float wasn't quite right, either. Alright, should work now, I thought. The engine ran much better and didn't have the same sputtering problems from before, but it still fealt like it was missing.
TIming was right on as per Chilton's guide, so I pulled the spark plugs. Seems the carb was running so rich the plugs quiclkly coated with carbon and weren't sending enough spark. Cleaned the plugs put it all back together, and closed up for the night.
Next day, turned the key and engine cranked, but wouldn't fire up, so I pulled and replaced the rotor and cap. Still nothing. Went out to lunch and when I got home, realized I'd left the key in the "on" position for about three hours
Here's the problem: I'm getting electricity to the dizzy, but it seems somewhere between the coil and the plug wires the juice is dying out. Could my stupid mistake with the key have killed my pertronix ignition? Will replacing that be the panacea to this electrical problem?
:idea: Here's another conundrum, I was still having this same electrical problem before leaving the key on, so while the ignition could very well be damaged, I'm sure I'll have only solved half of the problem. Any ideas?
And here's some details about the car: Pertronix coil and ignition, new fuel pump, stock engine with .030 over, Autolite 1100, and plenty of elbow grease.
Thanks all in advance for the help, any ideas will be greatly appreciated!
~Bobby
~Bobby
