Thanks for getting this fantastic board back up.
Well I got my new 78 200 head and am loking forward to getting all the pieces to put the weber 2 barrel on along with my headers for my 64 Econoline PU. My question has to do with the rocker arm and push rods. I remember someone saying that you should mill the head .06 to maintain the compression ratio of the old head and the best way to do that is use the adjustable rocker arm assembly from an early solid lifter motor. To go along with that you must use the bowl shaped push rods. Is it nessassary to shave the head in the first place? There is no adjustment on a hydrolic cam assembly correct?? Are the metal head gaskets available from anyplace??
Thanks again for all the help in the past as well as the excellent reading.
Steve
Steve
