Great fuel economy on a Kubota EB300 powered 120 volt generator project. Information that can be useful for others.
63 Sprint
2K+
Supporter 2021
Supporter 2023
As some know. I’ve been in micro power plants for 17 years for homes. I’ve also been involved in micro-cogeneration. We came up with some good designs and ideas. Unfortunately, the EPA came up with new tier regulations, and in 2006, this put the brakes on importing non tier certified engines. We were good for a while. At the time There were still plenty of small surplus industrial diesel engines available being sold for $500.00 to $700.00. They were sold cheap because they were no longer tier compliant to current EPA standards. In a nutshell, the APU manufacturers had to get rid of them. Unfortunately once they were sold, finding reasonable priced engines were slim.
Some non compliant models that were sold at a fraction of what they originally sold for:
Kubota EA300
Kubota Z482
Perkins 402C-05
Cat C.05
Yanmar 2TNV70
After retiring, power generation is still a hobby of mine.
I made some very nice 2 & 3 cylinder diesel gensets for fun. And sold them to fund my next project.
Years went by and in 2022 I decided to build my last one for myself.
In October of 2022 I saw an ad in Craigslist for a Kubota EB300 diesel engine. I was looking for one for about 10 years. These engines are outrageously expensive.
If you were able to find a Kubota EA330 at a Kubota dealer about 5 years ago they were about $4,000.00. Some dealers were selling them closer to $5,000.00.
The Kubota EA330 was the newer tier compliant engine that superseded the Kubota EA300. The internal differences of the engines were the EA330 bore was increased, the cold weather aid pump was removed, the hand crank start was removed. Different injection pump timing. This was all done to pass tier emissions. The EA300 & EA330 had the same output.
Now the Kubota EB300:
It was used by the military. It was mainly used on the Abrams Tank Carrier to operate the hydraulics on the trailer. What was so special about this engine?
• It was exempt from emissions.
• They were set up to run on Diesel and JP-8 fuel.
• Some were equipped with an SAE flywheel housing to directly mount a pump.
• They were much more flexible of an engine and could be set up to operate more equipment than the other models mentioned above.
Added:
Below are pictures of the engine when it arrived. I lost lots of sleep because I purchased it unseen from a person in California. I was wondering if I would be getting a $1,000.00 crate of rocks.
That was the riskiest Craigslist purchase I’ve ever made. Glad it worked out.
The Generator head:
Years ago I was able to become a Meccalte OEM licensed purchaser.
I was able to purchase a Meccalte SA20-130/2 for an unbelievable price. These are designed to operate 24/7. They are used to operate the controls and fans on trailer reefer units. The whole generator head is designed to handle road shock and vibration.
Rating is 10.5 kva
Set up to operate @ 120 volts only. There will be a switch to operate 120/240. But 120 load will be reduced.
Has momentary surge rating wired to 120 volts only is 87.5 amps.
With all the mass of the engine flywheel, pulleys and generator rotor. Heavy loads startup of compressors RV AC units and other equipment that need high momentary surge to start Is a breeze. All that’s heard it a blip from the exhaust.
Picture of the rating label:
Performance Curves
Note: The mil. spec’d EB300 engines are deliberately underrated on what they actually produce. The graph below shows a truer performance curve of what the EB300 actually produces.
The EB300 engine speed is set to 2657 RPM This brings the voltage frequency to 62 hz with no load. When the generator is loaded to 3,000 watts, frequency reads 60.3 hz.
First load test October 1, 2022
At 20 amps I believe the test numbers were 122 volts @ 20 amps. It equals 2440 watts. So a 2500 watt continuous rating for this generator seems good.
At 26 amps at 119 volts at 59.6 Hz equals 3094 watts. So I believe it's safe to safe to assume that 3000 watts is a good intermittent rating.
At 30 amps it safe to say that the little engine is overloaded. It gave a valiant effort but from its numbers 118 volts @ 30 amps equals 3540 watts. And that was a hard load to maintain. I let it make the load for 30 seconds before letting off.
So what it comes down to is that it's a great generator for 2500 watts continuous rating and 3000 watts intermittent rating. The length of run time for the intermittent rating has to be figured out.
The engine still is breaking in. It will be a while before I am able to figure out it’s true capability.
About surge starting capacity, there is no question that this generator will start the rooftop AC unit on the RV. What the total surge capacity is? I don't know. As I mentioned earlier, the generator had no problem starting a 1.5kw nail gun compressor with the air tank having 120 psi pressure during startup. It seemed like it did not know it was there. The brief surge current was over 50 amps. Some day there might be a time that we will find out.
Did not test fuel consumption yet. But I can mention that the numbers have to be good. We will find out later during spring or summer.
January 29, 2023
This afternoon I just did a fuel consumption test.
The fuel level was filled to a scribed line in the fuel tank filler neck. The engine was fired up and warmed up for 5 minutes then, load of exactly 3000 watts was ran for Exactly one hour. Once the hour was up, the power was cut and the engine was idled for 2 minutes and then shut down.
The fuel was replenished with a 100 ml measuring cylinder. The amount measured to refill the tank to the mark was 1152 ml. (just under 39 oz)
I'm very pleased with the fuel consumption.
She is a keeper.
February 21, 2025
Two years went by, last week, I was bored and decided to try something with the EB300 engine.
I was constantly thinking about retiming the engine because it seemed to have more fuel knock than I liked.
I started by backing the timing off 3 degrees. Did a loaded run up to 3,200 watts and there was a difference.
Here are the results of the test:
For reference:
0.1mm shim decreases the timing 1 degree.
In the Kubota manual It states timing was initially set 24 degrees BTDC.
I installed a 0.30mm shim. This brings the timing to 21 degrees BTDC.
• The engine starts the same when cold.
• idling during warmup is quieter.
• At full rated load at 2,600 RPM it is much quieter.
• The engine starts has no signs of smoke while idling or under full rated load.
The engine will be left alone and will be rechecked in warmer weather.
A spill-over test will be done to verify timing before going any further.
I'm thinking that 21 degrees BTDC might be the sweet spot @ 2,600 RPM.
Extra OEM shims on hand:
1—0.10mm
1—0.15mm
1—0.175mm
2—0.20mm
1—0.35mm
1—0.50mm
Was a very simple job.
What's also great is the way the fuel system is designed. It re-primes it itself very quickly.
The next day
Decided to do more testing.
After thinking things over during the night, I decided to back off the timing another two degrees. Did another spill test and timing is near 19.5 degrees BTDC.
The engine started up fine. The engine runs much quieter. Been running it for about 2 hours with a 2,880 watt load and it seems to be using less fuel. The engine seems to less stressed.
Update:
Doing another load test.
Right now the generator has been running a 3,240 watt load for 3 hours.
• AC frequency 60.3 hz.
• Outdoor temperature is 46 F.
• EGT is 587F.
• Cylinder temperature 209 F.
• Radiator top. 197 F.
• Radiator is blocked about 85%
• Crankcase temperature.
Bottom 166 F.
Right access cover 172 F.
I originally spec'd the generator for 2,500 watt continuous load. Since the injection pump timing was backed off 5 degrees, I might be able to go up some. Possibly up to 3,000 watts.
Another test will be done in the summer to see if I'm willing to increase the rating.
2/23/2025 Fuel consumption test:
Did a 3,000 watt load test.
Fuel consumption per hour
920 ml.
31.11 ounces
0.97 quarts
0.243 gallons
The engine ran the 3,000 watt load before the test began. Every thing was monitored closely like before.
The fuel tank has a sight tube on one side and it was marked 3/4 of the way to the top.
Once the test started, there were no changes to anything. Once the test reached 59 minutes, 30 seconds. All electrical equipment was shut down and engine was allowed to idle for 20 seconds before shutting down. The tank was refilled with certified measuring cylinder marked in 1ml graduates.
This test confirms that the Kubota EB300 mil spec’d engine was originally set up to run optimally on JP-8 fuel. Backing the timing off just 5 degrees changed the performance of the engine considerably.
On January 2023 the engines economy was 1152 ml. (just under 39 oz) an hour. Today, 2/23/2025 After the injection pump timing was backed off 5 degrees, the engines economy is 920 ml. (31.11 oz.) an hour. That is a huge jump in efficiency for such a small diesel engine.
An engine that can run a 3,000 watt continuous load and use only 920 ml. of fuel is a very fuel efficient engine. A matter of fact many generator manufacturers can only dream of reaching such economy.
Four pictures of the assembled unit:
This one is a keeper and now in the next phase. Building a noise reducing enclosure.
Some good advice:
One of the reasons I posted this is to show how too much timing can hold back performance of an engine by too much additional combustion pressure the engine has to overcome by early ignition of the fuel. Diesel engines are much more tolerable than gas engines because the components are much heavier built to handle the additional stress. Most gasoline engines are not. This is why it’s so important to make sure cam and ignition timing is within spec. As we all know what happens to a gas engine when pre-ignition happens. If a member here has signs of detonation. Stop and fix the problem. Don’t keep running the vehicle.
Make sure the engine is set up properly to operate on the grade of fuel your using.
It’s been 11 months since this thread was updated.
The generator has been prepped for the storm that is expected to arrive tomorrow. The oil and filter/magnet screen were changed. Engine was loaded to full output and frequency was checked. It’s ready to go if needed. I have 18 gallons of fuel on hand. It’s enough fuel to run the generator fully loaded to 3,000 watts for a minimum of 72 hours if needed. The generator normally pulls an average load of 1,800 to 2,200 watts. So, fuel use will be lower than the 31 ounces an hour rating at 3,000 watts.
Just to inform members that the numbers posted are right up there with some of the world’s most efficient small diesel generators. What helps to get the efficiency up there is where the engine was set to run, and the generator head is way oversized at 10,500 watts. Generator heads are most efficient when they are only lightly or moderately loaded.
Prepping for the next snow storm. If we’re going to get lots snow, I hope we get the light fluffy stuff. If we get wet heavy snow. We could loose power. We will have a better idea tomorrow.
Do you know the HHV of your fuel? You can calculate your overall thermal efficiency that way, should be around 30%. The timing changes you made may not affect torque, however they would also affect emissions, probably oxcides of nitrogen, which im presuming you cant measure. I was involved in standby Generator sets for telecommunications, mainly in Papua Nui Guinea, and to less extent in Australia. these were mostly around 5kva, but up to about 300kva. A lot of small sets were lister powered, Rubbish engines. Later we used MWM and Deutz, bigger sets were Volvos and Caterpillar. here in Australia we dont get many power outages and we dont have the low temp problems. We are 50hz, 240v here, so 1500 and 3000rpm is usual. Interesting in any event.
I don’t know what the HHV (High Heating Value) of the fuel I’m using.
I do know:
On January 2023 the engines economy was 1152 ml. (just under 39 oz) an hour. On 2/23/2025 After the injection pump timing was backed off 5 degrees, the engines economy is 920 ml. (31.11 oz.) an hour. That is a huge jump in efficiency for such a small diesel engine running the same 3,000 watt load.
The EGT reads around 600 degrees F. at full rated load. (3,000 watts)
I posted this chart earlier:
It turns out that the engine runs right near peak performance curve on the chart above. It’s best to have the engine rpm’s run a100 to 200 rpm’s past peak curve. When the genset is loaded to full continuous output. The engine rpm’s will droop a bit and rpm’s should be close to peak torque curve.
I’m just seeing this thread for the first time. Great write up! Very interesting stuff. Are you familiar with the Kohler and Onan generators that were powered by the ford 300? I am thinking about purchasing one for a home generator.
Thanks,
Yes, I used to service them. They are nice and very simple to service.
The gasoline CSG-649 (300) engine should be able to turn a 40kw, 1,800 rpm generator head at full output.
The Propane or Natural gas 300 engine has to be de-rated. I’m not a 100% sure, I think propane fueled 300 should be able to turn a 35kw generator head at full output. And a Natural gas fueled 300 should be able to turn a 30kw generator head at full output. It’s always safer to run a little less than what the engine is rated at full continuous output.
When I have a chance later on. I can figure out closer numbers later.
If you have questions, or need assistance, please send me a PM.
Some information about the generator head that is on the Kubota EB300 powered build
The diagrams below is the only information that is easily accessible to the public.
Note:
The generator Model/Types listed above have been updated sometime after the above document was published.
The Model/Type I have is SA20-130/2
The picture below shows the identification / performance label on the generator head I have.
The diagram below gives OEM’s pretty good information on each Model/Type.
The SA20-130/2 has a unique feature. Looking at the vented end plate, you will notice that the end of the rotor shaft is not covered. This is done because an additional PTO shaft can be installed. I believe it was originally designed this way as an option so a reed switch assembly can be installed to operate an electrical governor controller.
The only modification that I had to do before the generator head was put to use was to re-locate the electrical strain relief fitting. This was a very delicate process. It involved clocking the stator to the right and moving the electrical strain relief fitting 132 degrees to the right. The gyptal paint coating on the rotor/stator windings and laminates have not been affected.
Most electronic governors are when constant frequency is required, and they usually take their signal from the output of the alternator, 50 or 60 Hz.
Since this is a thread about generators, maybe someone knows if it is true: generators put out more of a square AC wave and surge protectors can be damaged from them.
As you said, most. A few electric governor controllers used reed switch systems. They were cheaper and worked sort of ok on 1,800 rpm gensets but were problematic. Especially on 3,600 rpm gensets. I had provisions to install a reed system on my Kubota D1005, 3 cylinder, 1,800 rpm genset I built and decided to stay with mechanical governor. The mechanical governor worked fine. Set frequency to 62 Hz. with no load. When stressing the genset out to tripping the breaker, frequency was near 58.5 Hz. I felt it was close enough.
Picture of the Kubota D1005, 1,800 rpm genset getting ready for first test run and adjustments.
In applications that I worked on, yes. But, there are some pretty good generator heads out there. The industrial Marathon, Lima-Mac, Mecc-alte and Stamford generator heads I’ve used had no problems running sensitive equipment. The sine wave was clean enough. Never had surge protectors damaged or an inverter shut down when charging a house or small office battery bank or, operating sensitive equipment with any of the names I listed above. The cheaper house brand generators put out lots of trash and can damage sensitive equipment. I do not recommend them. My personal opinion is, they are only good for incandescent lighting and stove top heating elements.
A good generator head has <5% T.H.D.
I’ll stay on the safe side. I have a Honda generator with iAVR. But stable voltage doesn’t mean a proper wave Which from what I understand- the square wave damages surge protectors, even at a stable voltage.
Thanks for the info
My0.50😬😬
I don’t know anyone that uses Honda for industrial applications. Honestly, they are just a little better than one purchased at Home Depot or Lowe’s. They definitely don’t have the huge surge capability that true industrial heads have. I think they have about 2000 watts surge. (Which is not much) But, they are a good fit for light home use.
No the solid state invertor type generators, usually variable speed drivers, can put out a modified square wave output to try and get close to a pure sine cycle, the higher the frequency of the chopper, the closer it gets to a sine wave. Normal rotating alternators will produce a pure sine wave, but they usually have some distortion that makes it not pure. that was quoted in the spec as harmonic distortion less than %5. As to syrge protection, not sure on that, the whole surge thing is a "star trek" thing IMO.
I understand about the Star Trek thing, but I am in central Fla. lighting capital. I have had a printer, a microwave and an ac mother board all need replacing after pretty severe thunderstorms. And power outages quite frequently. I use Eaton surge suppressors. To me it’s worth it if I can keep from frying stuff. Just about everything now has a board in it😣😣
Im pretty lucky here, we are nearby to two large coal fired power stations, and Victoria has quite a lot of renewables, so outages are a once or twice a year thing, mostly during storms. Lighting doesnt seem to be a problem here, we do get them, but the system seems to be well protected. I dont have nor never had any protection. I do have a 4kW solar setup which is grid connected. Australia has a very high penetration of rooftop solar, and currently the government is offering subsidies for home batteries, the take up has been pretty good. I di a few years with a Telco on standby power systems so got involved in the supply/construction of these things.
