gt42 garret , too big?
garrett gt42 turbo was bought at good price... ball bearing.
still building my car ,, ohc for turbo with all preparations.race pistons bl& Peened rods.etc
for straight lpg..
is this turbo tooo big ?? or stick with my t04?
what motor would it be cool/ work in? a 265 hemi, i've always wanted a charger.
check out www.fullboost.com there is a guy with an XF running 10's and a huge turbo like yours and LPG
Ive got a TO4 but mines been built for 600hp so will suit upto what im after and glad to see someone else going LPG turbo, But dont be surprised if when you ring around for tuning or fitting of the LPG to suit the turbo your 1st couple of fone calls are a waste of time....Persist and you will find someone who knows wat they talking about!
One of my fone calls i rung a workshop which specialises in LPG and turbos yet they told me my system wouldnt work and was a waste of time, shit fuel economy and just not worth it, go figure! Their business is based around what? hehe
Sounds like the pest inspectors who find termites in every house.
C'mon Mr C, get it going! I want to see it at Calder sometime.
A lot depends on the trim of the GT42 you have and what the application is. The GT42 is very similar to the TA45 and there a plenty of TA45 series turbos bolted onto ford sixes. Both the TA45 and the GT42 use a 5/16" shaft up from the 1/4" shaft used on the T04E series.
See the attached link for the dyno chart of Anthony Brigg's TA45 turbo crossflow in his 9 second Cortina.
http://www.paramountperformance.com/customers/carimages/cortina_dyno.jpg
TA45 turbos (and the GT42) start with a 76mm turbine wheel which is a fair jump from the P-trim wheel which are only 60 odd mm( I can't remember exactly) This does give the Ford six exactly what it needs though and that is exhaust flow required to handle the 600+ hp the GT42 is going to want to make.
Are you sure the GT42 is ball bearing? I thought they were all plain bearing.
Also is the car an auto or manual. The GT42 will be fine with a stall converter around 3000 - 4000 rpm. Don't expect the car to be nimble around the back streets though.
Even with my T66 turbo crossflow, 3000 rpm converter and C4 transmission the 235/45/17" street tyres are no match for it above about 30% throttle. The boost comes on pretty hard as soon as that 3000 rpm converter locks up and loads the engine!
The amount of lag you get will also be largely dependant on cam selection, inlet manifold runner length, exhaust manifold runner sizes and exhaust system backpressure. Once you go GT42 you really have to start thinking BIG about all of these things too.
Big turbos need big volumetric efficiencies to work properly. You need big ports to fully use the flow of the GT42, you will probably need to go 1.5" steam pipe for the exhaust mnaifold runners which seriously reduces the air speeds in the runners and increases lag.
Alternatively you compromise on exhaust manifold runner sizes and use long inlet manifold runners and smallish camshafts dialled in fairly advanced etc keep the air speeds high at low rpm for good spool up but then you will choke the flow potential of the GT42 and you may as well be running a well setup T04E with a T66 compressor wheel which is still good for 700 flywheel horsepower.
whos mr c?
im going for it , if it don't work i'l go down a notch.
i gues im selling a big t04.......
ohhh and i found a goodie...
programable ignition only comp that works as an edis.... very cheap very easy... megajolt lite jr!!!!
did the ef falcon come with a 36-1 crank wheel, or did it use something in place of the dizzy???
CortinaD knows a fair bit about the megajolt ignition. He used one on his turbo Cortina. If I remember right there was an issue with the EDIS version of it because the Aussie ford have the module built into the ECU. ThE designers of the megajlt based it on the european stuff which has a seperate ignition module. He was trying to tsource the modules at one stage.
The EDIS should use the crank angle sensor
mark, ive got all the big gear ,and addo , i wish i had the time to get all the big gear together.
the original turbo had a very big exhaust side so i went the 1.5 diam pipes. the head has had some monster porting . wade lpg grind cam, ef intake.
bigggg cooler.
first get the thing together then inlet change, c4 race build and finaly, custom fourlink and tubs.
did i mention i was going to drive this thing to work... low boost of corse
body is straight .... for now
when done i want to give george a go but by then he'll be retired :lol:
