Drag-200stang:
So since you posted the info I tried to guess a bit and compute your car too, since the et is so different from Bigcatch I thought the comparison would be interesting.
I do put the 200 six cars about 150 lb lighter than the 289 cars so weight matters.
I had to guess the .050 duration of your cam at "216" degrees, usually taking 50 degrees off the advertised gets you close to the .050" lobe duration. Well ok sometimes. And I also guessed you did a pretty good porting job. So my guess is that your little 200 had
Torq 253 at 3700
Powr 210 at 5200
With some good shifting and average weather I then computed:
2.12 60ft
9.23 at 76.7 1/8 mile
14.50 at 93.6 1/4 mile
I know, back in those days the time slip just had the 1/4 mile et, and if you were lucky, the mph like "93", or "94". Sometimes not even the mph.
Does 93 or 94 sound close?
By varying the weather and a 5mph head or tailwind I was able to make the spread of 14.22 to 14.70 you mentioned.
Thanks for the data and memories, I ran now and then at Detroit Dragway too.
I think your 200 was quite a bit hotter than stock though!
