Hey all,
I said my car could hit 6 grand pretty solid because it's done it. My dad was the one who got it to six grand and I usually don't take it over 4 grand. Well, last night, I was driving around and decided to push it a little past 4 grand. 4 grand, no prob, 4100 (which I had done about twice before) no prob, 4200 no prob, but at 4300 the car seemed to fall flat on its face. Nothing cut out, but the way it fell flat was very similar to what the efi ranger I had been driving would do if you went to about 5700RPM (redline of 5500, I wasn't paying as much attention as I should have been).
I quick let off the throttle and then the car started acting up. The tach needle was "ticking" in 100rpm increments and my oil pressure was fluctuating between 25 and 40psi. The oil pressure will fluctuate like that at idle if you drive around for a bit, shut it off for about 5 minutes, and start it again. The problem was I wasn't at idle and I hadn't shut it off.
I pulled into the place where I work since it was basically right down the road and I needed to stop there anyway. I was talking to my one co-worker about it and he said it might be because the motor is "used to" a top rpm of around 4 grand.
When I left it was still acting up somewhat so I brought it home. This morning I went out, went to start it and it fired right up with absolutely no hesitation and it runs great. All the symptoms seem to be gone (haven't checked for the restart oil pressure fluctuations) but I'm a little unnerved still.
Anyone else have a similar problem?
