By the way, do you happen to know how to check and adjust the timing on the straight 6?
First and foremost, you need to find TDC (top dead center). I'm sure you already know that but there are children watching.
Remove the spark plugs to help you turn the crank more easily. Use a socket ratchet wrench on the flywheel/dampener bolt to turn the crankshaft. Remove all the things in the way and put your socket wrench in place. Turn clockwise.
There are three or four ways to find TDC. I have done two of them
1) Finger in #1 (frontmost) cylinder. Stick your index finger in the first spark plug hole and turn the crank until you find pressure building on your finger. When the pressure stops building, that is +/- TDC. The if you can see the piston through the hole but there is no pressure when you turn it, you have the exhaust stroke. This is not as precise as the next two but you CAN tell if you are on the right stroke.
2) Long rod method. Same spark hole. stik a welding rod, dowel rod or long screwdriver in the hole. Turn the crank until it stops rising. That is the top of the stroke. You don't know if it is exhaust or compression.
3) Bolt or too-long spark plug. Screw one or the other of the objects in the hole. Turn the crank until it stops and you can't turn any more. Make a mark on the timing ring. Turn it back the other way until it stops. Make a mark on the timing ring. Measure the midpoint between the two marks. That is TDC. But you don't know if it is exhaust or compression.
4) String in the cylinder method. Stuff a bunch of string in the spark plug hole, Turn the crank until something stops or something. Then start to pull the string out at some point. I really don't know how this works but some guys swear by it. Whatever.
When you have found the REAL AND TRUE top dead center, mark it on your timing ring. They are notorious for slipping after 40+ years on a dry rubber bushing. In fact, you might want to make the mark on the bushing too with a white paint pen. Now you can start to set your real timing from the real TDC.
Of course there is the part about re-stabbing the distributor if you took it out. You can do this with the distributor in but you can figure that out with the position of the rotor and the #1 plug lead.
Adjust the timing by loosening the clamp at the base of the distributor shaft. Turning distributor counter clockwise advances, clockwise retards. Use a timing light on your new mark and check it against the degree scale to the side. Specs on line or use the 'search' function. Stock adjustment will be with the vac canister at about the 2 o'clock position when facing the block from the driver's side.
