Hello all,
I know i've asked about harmonic balancers for the 250 before, but i'm now at a stage where i need to buy one and i am still unsure what to go for.
My engine builder has said i should probably go with a fluid damper, but these cost $375 (Innovators West or Fisher Concepts). The guy at damper doctor says his recon units would be fine and they are a lot cheaper.
I'm building a 250 with Mikes Alu head and a blow through twin turbo set-up running 10-12 psi and max rpm of 5500-6000.
Do you think i would need a performance damper or will a damper doc recon unit be sufficient?
Any advice is greatly apprieciated.
Thanks
Thanks
