Taken from another thread...Thanks MarkP
So I have a 81 Big Bell stock rebuild with a OZ head. Nothing was taken off the block. I understand that steel gaskets were not used in OZ. I have a FelPro gasket. Anyone care to take a stab at what my compression is provided the head is stock, and what it would be if I used the steel or .027 gasket. I wonder if this is why I have been able to run so much advance.
Well, the 'stock' gasket IS the steel gasket. All of the aftermarket gaskets are composite type and are thicker than the steel ones, which causes lowered compression unless the head is milled by the respective amount. For instance, the stock steel gaskets are about .020" thick installed, while the popular FelPro version is .055" thick installed. In an otherwise stock engine, using the FelPro gasket lowers the 1980 3.3L compression from the original 8.5:1 to 7.6:1 - dismal at best (I did this 2 years ago, not knowing it at the time, and being in too big of a rush to check). Ford made a replacement gasket of the composite type which is .027" thick as a fix for leaking head gaskets in warranty situations. I have a couple of these left for sale, if you want one. They seal better than the steel ones, which can be tricky to seal and assemble unless you're good at it.
