history/Issues: low compression on a couple cylinders and pretty much not firing #2 at all (spark but no bang)
Pulled the intake, header, and head tonight. Besides what looks like blown headgasket areas, I don't SEE anything that stands out. Moderate carbon buildup (ran really rich for a while), valves all LOOK about the same and seat about the same. Pistons all about the same too.
Questions:
- could blown headgasket yield low compression (I know the answer is yes) BUT could it do it without running hot or mixing fluids (coolant/oil)? I had no other symptoms
- could blown headgasket keep a cylinder from firing if there was spark to the hole? I was able to pull the plug wire off while running and it never changed the idle. Did for every other cylinder
- I found a BAD intake leak right at #2 intake runner a week ago (about when things started getting worse). Could a bad intake leak (especially right at the weakest cylinder) yield no bang there?
- I know there was spark to the plug BUT I have started seeing some arcing of spark lately from the coil boot out to the coil terminals and even from the spark boot (not sure which cylinder) to the block. I have good 8mm wires on my MSD but I guess I need better. If I pull a plug wire off while it's running, the coil arcs practically every time that cylinder would fire. Like the spark didn't have any where to go out te plug wire, so it popped at the coil. Makes sense? Just bad wires?
- can you test for bad rings with a head off? Should I be popping the pistons out to check the rings?
- can you check for valve's seating fully? They LOOK like they do, but that means nothing.
I'm thinking of taking the head to be ceramic coated to match the OZ intake. Might look really cool.
Thanks all.
Questions:
Thanks all.
