no, I have250 ci.
C if this info comes thru:
________________________________________________________________________
Starters	157 tooth M/T & A/T
                                               164 tooth A/T	     164 tooth M/T
Ford Racing High Torque	      M-11000-B5  1	M-11000-MT164
Power Master   3124/9162/9103/9603/9503/9403	9604/9504/9403
____________________________________________________________________________
http://www.moderndriveline.com/Technica ... ersion.htm
_______________________________________________________________________________
oth flywheel then you will need the 3/8" depth starter (see chart).
The Details
As seen in Powermaster's "Ford Starter Tech Bulletin" there are 2 critical dimensions, the diameter of the registration hole, and the depth of the ring gear.
Ring Gear Depth	Registration Diameter
164 tooth, M/T	3/8" 	4.130"
164 tooth A/T
157 tooth M/T & A/T	3/4" 	4.084"
If not ck the link in the middle of the 2 'charts'.
Again, there's plenty threads on this here on our site. I just won't search 4 U...
 EDIT:
EDIT:
no, I C the formatting did not come thru, ck the link.
