Well...day 2 of engine re-assembly is going pretty good. i've the got cam shaft in, the double roller timing gear set on, the oil pump on. I'm stuck on the distributor though. I'm trying to make sure that I get distributor on the right gear. Anyone describe or take a picture of the rotor at TDC on a 68 block, dual advance distributor?
Does it really matter so long as I mark where TDC is for the rotor and put the wires on in the right order from there? Thanks.
Slade
Slade
