Thanx to all that have put up with me to this point-your info has gotten me runnin better, but I'm still not quite there. Problem-the car idles pretty well, but under light accel, it stumbles until I open up the other two carbs and build some rpms. It then comes to life, but still not what I'm led to believe it can do. I'm getting pinging in the mid rpm range which I'm gonna blame on the vac advance. I'm runnin the stock jets and some have told me to jet up the main carb. The plugs on the middle two runners came out a little sooty though which would indicate a rich condition. I do however hear the middle carb spitting at idle which usually means a lean condition. Anybody out there experience this/explain this? What kind of vac readings should I get from the port and manifold vac lines with the setup I have? I'm getting about 13 lbs. from the port which seems a little low, but the guage is steady so I don't think I have a leak- the timing mark stays very steady too which backs this up. Somebody please make my Christmas!!!
Thanx again!
Thanx again!
