Boburban30
[facebookpost]https://m.facebook.com/photo.php?fbid=10154586455753107&id=520018106&set=gm.1177601855696332&source=48[/facebookpost]
Not sure how to post photos so I am hoping the above facebook post to my picture works.
I want to put a brake booster on my 66 200 but I am not sure where to pull the vacuum from. I think I found 2 vacuum ports on my intake and 1 on my carb. The 1 on the carb is currently going to the distributor, 1 of these ports I think is a vacuum, is going to the pcv valve, and the second port has a screw in it. Is this spot with the screw in actually a vacuum port and is this where I would run the booster to?
Sorry if I am completely wrong here. I knew very little about these older cars and all the work I have done so far has been by being self taught thru youtube.
