As some of you may know, I reciently upgraded my head to a M code head and adapted a YF off a 300. I timed it to the best vac and it idled great. Almost no misses. Purred like a kitten! But when I was cruising with RPMs around 2000-3000 it bucked and missed but only when holding at a constant throttle position. I went up a steep grade with engine up to temp and there was no pinging. So I timed it with a timing light and it was WAY TOO HIGH!! About 20* or so! So I brought it back down to 14* and the hesitation went away but the idle was not so good anymore. What gives?! Any thoughts?
I love this carb and head so far. It really gets up there and goes. I can now do aroung 5500rpm and it will pull all the way through!
Later,
Paul
Later,
Paul
