hotrodbob
Someday I know I'll get this thing done. Anyway, I was just given a Holley 2 Bbl adapter. It must be for a Autolite or regular Holley carb as my Pinto carb will fit inside the bolt pattern.
Three questions:
I have a Isky 262 cam, .040 off the block and head, .030 over bore, big valves and a header.
1.) Is the larger Holley a good choice over the H/W Pinto carb?
2.) What is the CFM of this carb? I was told the H/W is about 275 CFM. The calculations I've done say I should have 305 CFM.
3.) The adapter hits the Valve cover. Is there something that should go under it to raise it up?
Thanks,
			Three questions:
Thanks,
