Hmm. I just ordered a second H/W 5200 from Tom Langdon to replace my messed up first carburetor. I didn't want to spend a lot of money on a carb because I'm saving money for the new intake and head, and also to dig myself out of a disastrous rack and pinion installation gone horribly awry.
Anyway, the carb came with a water-heated choke assembly with electric assist. I would like to use an electric-only choke. I ordered one long ago from I-dont-remember-where. It's just a black, circular piece of plastic with coil spring inside of it.
The problem is that doesn't fit tightly to the carb.
If I'm doing this right, the black electric choke mechanism fits onto the carb (with the little pin sticking into the hole), and then it should be held in place by a metal ring with three screw holes. Even when tightened down, the choke mechanism can move freely. No good.
The other thing I don't understand is that on closer inspection there is another pin on the carb side that pivots along with a triangular piece of plastic on the outside of the carb. The water/electric choke seems to mate with both pins. The electric-only does not.
What am I missing here? A whole piece of something? Or is this one of those crazy works-on-a-real-weber-but-not-a-holley/weber situations?
I'm irritated.
-marcus
I'm irritated.
-marcus
