Hi all,
For the record, a stock 1967 200 I6 Mustang was dyno'ed at 67 rear wheel HP by AK Miller a number of years ago as a baseline for mods developed by AK. As noted earlier, Ford stated the net HP of this engine as 91 @ 4000rpm. This appears to be support the common view that the drive train will absorb 25hp. Mustangaroo's 105 rear wheel hp was obtained with a Holley 5200, header, upgraded ignition, 1.6 adjustable rockers AND a 2V head. Add the 25 back and you have 130 at the flywheel (net HP) without a cam. How much of this increase you can allocate to the head is yet to be determined. Someone will have to dyno a car with a 5200, header, ignition, and 1.6 rockers before the value of the 2V head can be stated. However, if you want a guess, Clifford has advertised for years that their carb, header, and ignition upgrade is worth 25% at the rear wheels. I can state from personal experience that the 1.6 rockers make a difference. So, for the sake of discussion, let's say 30% total. 67 x 130% = 87. Add back the 25HP and you have 112 at the flywheel (net HP). So what is my point, I don't think it rational to assume that a 2V will add 35HP to a stock car. 18 to 20 is a more reasonable expectation. However, we will not know until a vehicle with the appropriate mods is dyno'ed.
Torque vs HP. I agree. The way I heard it was ...you race HP, but you drive torque... I like a strong bottom end. Torque has been high on my list of priorities with all of my mods. Second is weight control. Lite weight and lots of torque is fun to drive. It leaps across wide intersection in a single bound. Sorry, couldn't help myself.
My 2 cents - Steve
