Alright, more questions.
I have an E0 head that is at the shop as we speak (or type) getting rebuilt to performance spec's.
I'm planning on mounting a Autolite 1101 from a 1969 250, so I got the correct carb mounting plate from Linc (thanks), and now I have no idea where to mount the little rod that my throttle linkage slips onto. Previously, it mounted on the carb mounting plate.
I specifically got a fixed throttle Autolite 1101, not cable, because I was told I wouldn’t have to convert my mustang to cable throttle, but now I think the conversion is inevitable. Any ideas on where to mount the rod?
I was thinking I could somehow drill a hole in the carb mounting plate.. not all the way through, tap it, then just screw the rod right in, but if you guys have any better ideas, spill.
Another idea: My 80 head had an EGR port, and the some bolt holes to the sides, maybe i could somehow screw the rod into these bolt holes?
By the way, I'm imagining all this in my head since my head isn't around, so if i gave some off the wall idea, just disregard it without chastising me for my stupidity.
1968 Mustang 200ci. C4
