I was Dogpiling this topic, and came up with this tidbit. Unfortunately I closed out the window (site) I got it from, iirc it was 'nastyz28.com or something like that.
1. Test Procedure and Criteria
a. Measure the flow of the PCV valve in standard cubic feet per
minute (SCFM) vs. pressure differential across the valve over a range of
operating pressures from 4-22 inches Hg., at standard atmospheric
conditions (21.1 [deg]C (70 [deg]F) at 755mm (29.92 inches).
