My FSPP camshaft degreed in @ 1 degree advance from split overlap.
Just to be on the safe side especially if you are not using the FSPP aussie timing chain & gears. Degree it in, its better to be safe than sorry.
You need to see what you have then make the desision to advance it if is necessary.
To advance or not to advance, really depends on your intended use of the vehicle.
For street with a stock converter & a stick shift with close to stock gear ratios yes advance the camshaft 4 degrees.
If you have a very loose converter or a lot of gear in a stick shift or both you might just want to install the camshaft straight up, if you need the low end torque advance it, if you don't, install it straight up or maybe 2 degrees advanced. William
