Need a little advice from someone who is more experienced with lifter problems I have some lifter noise on cold startup which goes away at temp. Since I had the head off anyway I thought I would replace the lifters since the engine is high miles but still has good oil pressure and burns a very minimal amount. I understand the concept of how hydraulics keep the slack out of the valvetrain but I have no experience at troubleshooting them. After a lifter has run in an engine awhile and removed shouldn't the spring fully extend it as a new one does or does it stay compressed near where it was running in the engine? Common sense tells me that the spring should extend it, but I've been wrong before (many times). Also has anyone had good results replacing lifters on a used cam, I know they should be replaced together but it just ain't in the budget right now. Any help will be greatly appreciated. :| :help:
