I don't think a header is the solution to your problems, especially with a 170. Very expensive for very little gain on a stock engine. In my experience, an electronic ignition and a bigger/better carb made more of a difference in power than the header/exhaust did. Think in terms of systems, though. If you want more power then consider a package such as mild porting, ratio rockers, bigger carb and electronic ignition. All of these will work together to get you some more high-end power.
On the exhaust side, I'm pretty sure the later 200/250 exhaust manifold is considerably larger than that of the 170. I'd think that manifold with a larger exhaust would complement the mods listed above nicely.
FYI, my car originally topped out around 70-75. It'll now pass 100 with no problem.
