Well, I rebuilt my carburetor over the weekend and had a bit of sunshine yesterday afternoon so I thought I'd reinstall it and give the engine a go. So far so good. I was able to adjust the fixture screw, which had no effect before, and the engine ran even smoother. No surging. But...I still had a knocking sound coming from the #5 or #6 cylinder. Lifter. Or at least this was my first thought. Then I thought, maybe I have too much initial advance. So...I cranked over the engine until I was on the compression stroke for the #1 cylinder (had help this time - finger check). The balance was off with the timing marks on the block so I spun the fan until it lined up with 10 degress. Next, I removed the distributor cap and made sure the rotor was lined up with the number one spark plug - it wasn't even close. Maybe 20 degress off. At this point I thought I could be a tooth off on the distributor so I removed it - this is where it all goes down hill.
After rotating the distributor a bit, it slipped back down into the block with no problems. I tighten down the adjusting bolt at the base of the distributor a bit and try cranking over the engine - notice I said try.
Nothing. I'm not lighting any fuel.
I'm not far off because at one point the engine started up and ran for about 2 seconds but I couldn't rotate the distributor anymore - it was hitting the block.
So I called it quits for the evening. If it doesn't rain today, I'm going to try again after work.
Man, I wish I had an expert close by who could tune the engine for me.
-Chris
-Chris
