I plan on making a windage tray for my 200. I plan to use thin sheet steel and sandwich it between the oilpan rail and the oilpan rail gaskets and use studs instead of bolts on teh side to locate the windage tray.
My question is some of you have worked sheet metal more than I have. What is a good way to cut the slots I want to allow for thrown off oil to return to the pan?
And some of you are probably saying why bother? you wont pick up more that a few HP?
Answer: In tests on V8 cars, some engines picked up as much as 13hp at rpms between 2500-7000rpm. Way I see it every little trick I can use to squeeze even a few "free" horepower adds up on the dyno. And It should be a fairly cheap project once I finish designing it and building it.
And my Mustang is intended to be a highway cruiser/Bracket racer so it will see lots of 2500-5500rpm usage.
I have drills, a Dremel tool, a die grinder, a hacksaw. I was thinking I might try a router bit in the die grinder or use the Dremel and a cutting wheel. I have nefver tried to cut a long slot in sheet metal.
