I believe that that is incorrect. cylinders 3&4 have their exhaust ports siamized thus those exhaust valves are side by side. Unless I am missing something the intake valves are the ones that are next to the intake ports and exhaust next to the exhaust ports. Therefore it would be EI-IE-IE-EI-EI-IE part of this is to keep the intake log as short as possible and also to isolate the exhaust heat from the intake as much as possible.
Plugs are more centrally located in the head Keep it simple- intake valve lines up with intake port- exhaust valves lines up with exhaust port exhaust tubes line up with exhaust port and knee bone is connected to the EI EI O
