Car 61 Comet donor 75 Granada
Took the 250 and C4 out and putting it into the Comet (if you haven't been following my posts)
Now is time to think about the ignition system. It has a Dura Spark 1, with a breakerless dizzy. I want to get this thing started and rolling down the road ASAP. I pulled all the wires out of the granada and layed them out.
(see pictures)
the first picture and connections are pretty straight forward, going to Alt, starter, and I'm assuming the wire labled (?) goes to the ignition switch.
But the thick yellow wire coming off the same side of the solenoid, goes to other side of engine bay, and both go thru the fire wall on oposite sides of fire wall.
what goes where?
2nd pic-
white cresent thing is labled Tech Tester and clips onto coil
From there wires head all over, connecting to connectors, and back together again, heading in and out of firewall. I'm assuming some head to dash for warning lights.
Is all this necessary?
is a Dura Spark2 less complictaed?
Should I go with an after market set up?
I do know from what I've read, that this DS1 is a P.O.S and doesn't give off much spark. I was thinking of up grading at a later time, but maybe now is the time.
I dunno, but what I do know is I want to get this thing running.
thanks
(see pictures)
what goes where?
2nd pic-
thanks
