The reason it took me so long to put this up is.........well I am lazy. Sorry.
Well here it is, I cant remember the exact prices of some of this stuff but it should be really close anyways.
'87 Buick Gran National T-3 with .82 exhaust housing....got it at the Buick Nationals in KY, I paid $50 for it knowing it needed to be rebuilt. Rebuilt it with a rebuild kit for $15 I got through a friend. It is still leaking oil so I am working on that right now. I like the GN turbo because it is about the right size for our small sixes and they can be found easey and bought, worked on and upgraded for cheap.
90 degree heater hose to clear turbo....got it from NAPA, part # 10078 $11.99
Brass "T" for oil feed line and oil pressure gauge....from NAPA, can't remember the part # but it was around $4.00
Brake line to go from brass "T" to turbo....got it from NAPA, Can't remember the part # but it was aroud $3.00
Carter "strip" pump for SBC with 200 pump arm in it modified for boost with brass fitting tapped into air port for vacuum line....Got it from Summit, part # CRT-M4891 $61.95
Home made three bolt turbo exhaust flange and turbo bracket....Me and my friends with some scrap metal, hammeres, welders and cutting tools did the trick, free
Holley nitrophyl float noched with jet extentions....Got it from JEGS, part # 710-65228 $16.99
Hydrolic hose for oil return 15" long, 1/2" inside diameter with fitting....got it from TSC, Can't remember the part # around $18
'98 Jeep Grand Cherokee V8 air bonnet....could not find one in a junk yard so I had to get it from Jeep, Cant remember the part # it was about $50
It is going to be hard to tell you much of a price on my exhaust because I got screwed on price and quality the first time I got it done and had to get it done over again by another shop. I am going to say you should be able to get it done for around $150-$250 at the most.
I can tell you about my muffler though, 3" Dynomax race muffler Ultra Flow Oval....My friend got it for me for Christmas but you can get it from Summit or JEGS, part # WLK-17223 $65.88
Well, that is all I can think of for now. There is really not that much to it as far as parts go.
Dan
Dan
