Is there a way to increase cylinder compression? After I rebuild my engine, I performed several cylinder compression tests on the motor. What I noticed disturbed me a bit. Before the rebuild the average of the five (no.2 was 30 PSI) was 150 PSI or so. Now, after the rebuild I'm not getting anything above 130 PSI.
Before the rebuild it had the original steel head gasket and stock pistons. Now, .020" over pistons (small dish) and FelPro head gasket.
The engine runs very smooth (as long as it gets fuel, another problem) but should I really worry about the difference in cylinder compression? If I remove the cylinder head and shave .045" from it this should increase the compression, right? Does it matter?
-Chris
-Chris
