65 Mustang
Hello Everyone,
Looking to increase the compression in my cylinders. Ran a hot engine compression test not too long ago and found all the cylinders to be somewhere between 120-130 psi. The service manual says the compression should be between 155-190 psi. While the 190 may be wishful thinking, I was hoping to at least get close to the 155. My first thought is to have my cylinder head reconditioned and shaved down. I am not sure if it ever was. How do you determine how much should be taken off? While the cylinder head is at the machine shop, is there anything else that can be done to enhance compression? Thanks
