Varilux
After recently deciding to stick with the 200 inline in my '65 Mustang (recently rebuilt .030 over with a mild cam), I ordered a DUI from Performance Distributors and a clutch kit from Modern Drivelines. I've done some reading here on both projects (learned a lot about the SCV valve on one thread), but still have some questions...
DUI install- I understand I need to hook the vacuum up to the source on the log right below the carburetor...
1.) I'm planning on running a rubber hose for the vacuum line- anyone know the thread/size of the plug that is currently in the log (so I can get a fitting for the hose)?
2.) Same question for plugging the current vacuum source- what thread/size do I need to plug off the vacuum source on the carb?
3.) When I ordered the distributor, I had to answer a whole bunch of questions about my compression, cam, etc. I assumed this meant Performance Dist would be curving the distributor for my set-up (but from many threads it seems I need to take the distributor to have it "recurved" after I receive it). What's the deal here?
4.) At the end of the day, is this a job better left for a professional mechanic? I am pretty good at hanging parts (have replaced manifolds, A/C systems, etc.) but my abilities at timing consist of going by vacuum and ear.
Clutch replacement- I had a T-5 installed when I restored the car a couple years ago, and unfortunately did not realize the clutch was adjusted way too light. As a result, it slipped and- I believe- eventually warped something in there. I adjusted the clutch properly (I'm running the original z-bar linkage), but I get a lot of clutch chatter in 1st and reverse, and if I have three passengers, the clutch definitely slips through 1st & 2nd. I ordered a new clutch kit from Modern Drivelines (where I sourced all the parts for the conversion), but they did not have a resurfaced flywheel.
I have the 8.5" bowl flywheel, and the helpful guy at MD mentioned I really need to make sure the shop knows they need to "resurface both sides of the flywheel." I mentioned this to the mechanic where I plan to take the car (Kane's- they do flywheel resurfacing for most of the garages in the area), and the guy (who used to mechanic for Dallas Mustangs) said he had never seen the 8.5" bowl type- but he could resurface almost anything.
1.) Is there any special instructions he should have regarding resurfacing this flywheel?
I'm looking forward to getting the distributor and clutch sorted out, because- other than the fact that the car is definitely not efficiently burning fuel (only getting 16mpg, and there's black unburnt fuel smoke when I'm backing into my garage- along with carbon blowing out the tailpipe when I start) and the wonky clutch, the car is a blast to drive with the T-5 and 3.20 diff (I swapped in an 8" diff when the 7.25" failed, and installed Chockostangs' V8 disc brake/steering/suspension package earlier this year). Trying to get the car in tip-top shape to make the drive from Dallas to Charlotte for the 50th celebration next year.
Sorry for the length- thanks for any info!
Pete
http://forums.vintage-mustang.com/a...-conversion-complete-then-some-must-qtr02.jpg
Pete
good luck
, I only want to help , been doing this a long time , I know the value of a Dollar and hate to spend where the benefit ( or lack of it ) is no good , I have no ill will towards DUI ( Davis unified ignitions ) but I do not think they are knowledgeable on the Falcon 6's, the Tech Tips need updated IMHO , nuff said
