falcon1963":1fsgtlfo said:The isky will give you more low end & midrange, but the ci cam might produce ???? a little more top end.
The isky requires stronger springs than the ci cam, so i would guess the isky has a faster rate of lift.
For regular street driving the isky would be the better choice, with a cam with this short duration.:
1967JMG":1b9j2x2w said:what if instead of the oz head this was for a CI aluminum one?
falcon1963":22rbum1w said:Since you only have 9:1 compression, the isky will be a better choice than the comp 260 for increased street performance but still retain decent fuel mileage.
If you just want more performance go with the ci 264-274.
If you want still want more performance go with schneider cams or one of comp cams xtreme energy camshafts, but you will need stronger valve springs to handle the more aggressive profile.
rocklord":sk0bbx8i said:Isn't it the other way around; the more overlap you have that bleeds off excessive peak pressure, the higher your static compression needs to be to maximize the performance benefits of the cam?
rocklord":yovlnscg said:Isn't it the other way around; the more overlap you have that bleeds off excessive peak pressure, the higher your static compression needs to be to maximize the performance benefits of the cam?
CobraSix":2p0d1o4q said:And how with force compression affect this?
