Well we finally got to the dyno last Sat. for a SVTOA Dyno Day. So we were only allowed to do pulls, not to really tune the car. There were a lot of cars that needed to get dynoed.
The main objective for me was the air/fuel ratio. I totally believed that the car was running lean based on how the plugs, turbo and down pipe looked. Boy was I wrong!
We were running the car very rich at less than 10:1 A/F at idle (it was off the chart) and at 15lbs. of boost it still didn't get much better than about 10.8:1.
For those that don't know....the approximate "optimum" ratio for a turbo/blower motor should be around 12.5:1-13:1. Normally aspirated is approx. 14:1.
But you probably only want the numbers huh?
So we pulled a 227.5 hp and 320.9 lb/ft at the rear wheels. The torque number was at 2513rpm.
This is the same tune up that ran a 12.49@109 2 weeks ago.
So all in all it was a good outing due to the education. I personally was a little disappointed with the numbers but because of the "richness" it was explainable.
We did get a video of it and we're working on getting it posted.
Later,
Will
Later,
Will
