I have been trying to come up with a way to use a dual advance with some check vlave and vac line trickery to retard it under boost. I think I can get it to work but just haven't sat down to thoroughly think it out.
Does10s":3sqto6rj said:In a nutshell.... TO-4 turbocharged, 58mm,
62fairlane170":3sqto6rj said:I have been trying to come up with a way to use a dual advance with some check vlave and vac line trickery to retard it under boost.
MandarinaRacing":260risul said:You can also try Accel part # 0375, they're a $1.50
xzerokidx":r0lrnklx said:then just turn the boost all the way down when cruising around town, then fuel consumption goes down because you wont need any extra fuel than a NA motor...
6bangerwanab":r0lrnklx said:if you can keep your foot out of it..... it would only boost when you were accelerating, not all the time. so then the power was only there when you needed it.
