Length of Cleveland head bolt?
MustangSix
2K+
You guys who own a 351C or a Boss 302.....what's the length of the head bolts from under the head to the end of the threads? I'm guessing it should be between 4.00 - 4.25" (101 - 108mm). I know 351C's have a 1/2" bolt and the boss had 7/16"......
PM AlloyDave..he may know!
The heads of the bolts are bigger on some 351W's too. I think I know what you are doing...looking at increasing the clamping rate on the camshaft side of the block. Knock 'em dead, Jack!
Hello Jack,
sorry i cant give you any measurements at the moment , the guys who i get them from are out of stock ,and the book i have doesnt
have any measurements.all i can tell you is a few ARP p/numbers which might help.
302 BOSS ARP 154-3602
351 WINDSOR ARP 154-3603
351 CLEVELAND ARP 154-3604
302 WITH WINDSOR HEADS 1/2"-7/16" STEPPED ARP 254-3708
351 SVO CLEVELAND IRON BLOCK ARP 254-3701
Maybe take your ruler into a speedshop and check some .
cheers dave 67xr6
Say wot...are they French units...wash your mouth out JD!
I'll have 4.25 inches of what your having, JD!
ps If your Cleveland 351 has injection like your old HiLux 302, I'll have four of them. My Dunedin mates are V8 die-hards!
Actually I had an opportunity to score a set of head studs for a Boss 302. Now that I've verified length, these can be used to replace the head bolts on the Crossflow.
