Is that rectangular box going to sit on top of the log?
And feed thru orig inlet hole?
In my mind...with a single two barrel , I allways thought/ schemed about welding the rectangular channel to the side of the log., grinding out a rectangular hole into the log and closing off the orig single carb hole on top.( And close outer end of the channel with a plate ( obviously)
And mounting carb on the channel,
That way the carb sits lower, you aren't bound by orig carb hole restriction and get a bit of a inlet 'runner' in to the log
May need a heat shield under carb/ over exh
Sort of like my CAD model sketch
