as far as the three carbs go you could buy an offenhuaser manifold adapter from summit or jegs what this does is lets you drill a hole between the 5-6 cylinder and another between 1 and 2 the manifold sits on top holding the other 2 carbs. the offy gives you a nostalgic hot rod look and tons of midrane power mpg does not suffer so much because the linkage is set up progessivley meaning the outer two arb start to open at about 2/3 throttle.
