Looking for some 170 specs
Anlushac11
1K+
Cant believe I cant find this data on the internet.
What is the piston pin compression height of the 170?
What is the rod length of the 170?
I know the 170 is a 3.5" bore and 2.940" stroke so it cant use same piston
Thanks in advance
Mark.
EDIT: Found that 170 uses same rod as the 200. Now I can figure the compression height since i have rest of the figures.
Beck Racing's old Silvolite page says C/H is 1.58", and a flat top piston. That puts the piston about .04 - .05" down the hole at TDC. Works out to almost 8.5/1 C/R, which all sound about right.
You wouldn't happen to be considering taking a whack at the 107.119mph record in in F/GC?
Rick(wrench)
Rick(wrench)
Thanks again for the info.
I am toying with the idea running a shorter stroke 170 crank with long rods and custom pistons in a 200 block bored .040"
I have some nice pics of a built to the edge 365hp naturally aspirated 188 cid Argie inline six in a round body Falcon race car.
Way too many custom parts in the n/a Argie 188 so Im gonna cheat and turbo it.
My plan is to build a fuel injected, turbocharged, intercooled inline six aero nose Fox body Mustang convertible and make it look as factory stock as possible.
