loose dr classic inlines timing chain
has anyone had problems with the classic inlines timing chain being too loose. im wondering if i should buy a new chain for it or switch back to the stock chain after classic inlines is back up.
i think the dual roller with adjustable crank sprocket for a 100 is the way to go......timing chain is the weakest link in the drivetrain on these especially if you drive an automatic they take some abuse.
If you are concerned, put an ad in the wanted section of the forum.
Definitely don't go back to the stock timing chain.
there are two potential problem areas.Both because these are Detriot designed sixes with large "omg its that big?" production variances designed in...
First, there is potentialy a normal extra 3 thou play in the whole sprocket to crank clearance when its slid on , as the timing chainand sprocket is ex Austraila, and is designed for an Aussie 144/170/188/221/250, and the crank snout on them is ever so slightly smaller than the US engines. Bolt tightening solves that.
Additionally, the timing chain is normally loose in service anyway from brand new. Single or dual, there is play. The factory clearance before replacmentment is very large. If defection is greater than 500 thou, replace the chain.
Half a bleeding inch, ye gods...see the section on timing chain, you won't believe it...
http://vintage.mitchell1.com/PClubData/ ... 816068.pdf
That's why the final HSC's ran a chain tensioner.
thanks for those awesome spec sheets X :beer:
I know that when i installed the chain a few years ago, there was some play but not anywhere near half an inch. I can hear it slapping a little and I noticed that when I rev it and let off the throttle quickly, the engine acts like its going to stall and I can hear the valve train delay, ill make a vid
I went back to the stock chain.
Funny thing though, I was able to source a replacement double roller chain.
Apparently there was an older car, a Morris Minor or something like that used the same gear set.
Do you have the application or part# or link to the supplier??
i spotted the chain tensioner of which you speak. i wonder if one can be either adapted or created for the six?
Water pump might eliminate the room to attache it.
www.fordsix.com/forum/viewtopic.php?f=1&t=69097
xctasy":6r7ma145 said:
The US HSC 2300 and 2500 are thechnically not 3300/200 CID I6 based fours at all, as they use the US/Australian 221/250 cam positioning. The main bearings are 250 sized, and nothing from the 3.3 fits the 2.3 or 2.5, as the 4 cylinders rods, crank stroke are all different. Not sure on the oil pump.
Fours vibrate badly in line north south set ups, which is why you never saw HSC 2300/2500's in rear drive situations. In FWD, West East situations, all the vibes can be largely dampened out using the existing mounts. The timing chain though is still under imense stress, so you may be interested to know the HSC Timing chain isn't Aussie or US 221/250 based, but has been upgraded to a very special 46 link, 0.5" pitch item with 17 teeth on the crank and 34 on the cam. And a really good tensioner. Not at all like the 200 and 250, and the water pump has been placed on the side of the block, so the 2.3/2.5 has lots of space for the tensioner, which is taken up with the front mounted water pump on the small sixes.
I'd like to ask someone with a US 250. Bearing in mind how bad the stock 56 link 1 and 0.625" wide 42/21 teeth system is, wouldn't a used or new HSC Tempo or 2.5 Taurus item just bolt on and fix all the problems. Any one willing to have a go?
Same with the N code 6 inch 2500 HSC rods found on 1986 to 1990 FWD Fords with the 153 cube 2.5 liter engine ...likely to be a straight bolt in to the US 250, perfect to the thousandth to correct the 89 to 120 thou short fall of the 1.531" inch piston from the top of the 9.469" block with the 3.91" stroke.
Those Autoplus timing chain specs cover the Aussie, German Cologne and American engines from 1984 to 2000 ish, and are found in http://autoplus-tk.com/pages/fd.htm
If I'm not mistaken, the key kit is the same between the 8.66" deck 2.3 and 9.38" deck 2.5. Yes, they use the same cam to crank spacing as each other....and the 9.469" deck US 250 and 8.425 and 9.38" Aussie 188-221/250!
HSC 2300 (140) R,S or X code 84~94 FORD, LINCOLN/MERCURY
HSC 2500 (153) N code 86~92 FORD, LINCOLN/MERCURY
Cam Sprocket TK-FD203-A01, 46Link Timing chain TK-FD203-A03 1 Crank Sprocket TK-FD203-A02.
64 200 ranchero":3sluk0h2 said:
https://www.facebook.com/video.php?v=966464566720574&set=vb.100000711187478&type=2&theater&notif_t=video_processed
sounds like a cummins diesel.
