62Cometman
Hi all, I was hoping those of you with more incite might be able to answer my pondering question. I have a mostly stock 170 getting a mild rebuild with new rings bearings head mill .040, NOS headgasket, upgraded 1100 carb and dual outlet exhaust. Now this engine previously ran ok, cylinders 2 & 5 seemed to have a slight miss but after a slight valve job and 2 NOS pistons I should be back in action. I was hoping someone might be able to give me an estimate on expected whp ranges. I'm running a rebuilt 2.77 3 speed with a stock 3.10 7.25 rear. This motor is from a 62 so it does have the adjustable rockers and I'm still running the stock cam as no one that I've found, other than a custom grind from Schneider, has a cam for the non hydraulic motors .
Also does anyone have any idea of what the suggested Rev limit on this motor should be? I previously didn't push it much past 3,500 rpm and that was usually only on the highway when I felt very, very, brave and/ or needed to get around traffic.
Thanks for any and all help or suggestions.
