I plan to start building my ECU in a week or so, but wanted to gather this info before I get to the part of the build where I have to answer config questions w/o knowing the answer.
I'm building a mod-logged 200 MPFI just as a guinea pig to get the fuel, and spark maps correct before I convert it over to turbo, & upgrade to my other engine (250).
I plan to use Ford edis and modify the stock distributor to just drive the oil pump.
I am unsure about what edis to get for an inline 6.....(I just don't know that much about my options here).
I also want to know if anybody has a base start up map for stock config, using small injectors that they might be able to share.
Thanks.
Thanks.
